somervda
Oct 30, 2018Aspirant
6.9.4 hotfix has not fixed RN104 hangs
I have been using the hotfix 1 version of 6.9.4 since the beginning of the week 23Oct but it has not solved the file share hang problem introduced with 6.9.4. Is work still going on to fix this or sh...
- Oct 30, 2018
You can try the 6.9.5 beta and have solved this issue.
https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-9-5-T7-Beta-1/m-p/1656915#M10309
Icewaterhot
Oct 30, 2018NETGEAR Employee Retired
somervda
Oct 31, 2018Aspirant
Thanks for the directions - beta installed now, will drop a note if I see any more hangs (Hopefully not).
