JohnWB
May 01, 2013Aspirant
A better way to backup Duo to a USB drive ?
I have been backing up my Duo to a USB drive (formated with ext3) plugged into the rear USB port which has worked ok, if a little slow. I just turn it on once a week & do a backup which adds any new f...
JohnWB
May 13, 2013Aspirant
I do have a Duo V1 which as you say is not the fastest in the world due to it being USB2 unfortunatly for backups.
It works fine in normal use, I can play 40g movies over the ethernet to my Mede8er MED600X3D Media player with no problems.
