JohnWB
May 01, 2013Aspirant
A better way to backup Duo to a USB drive ?
I have been backing up my Duo to a USB drive (formated with ext3) plugged into the rear USB port which has worked ok, if a little slow. I just turn it on once a week & do a backup which adds any new f...
May 13, 2013Guru - Experienced User
I still use my V1's (though right now just for backups of my Pro). They've worked well for me over the years, and as you point out, have enough performance for bluray streaming.
Definitely slower than the newer models, but if you are ok with the speeds you are getting, there is no reason to take it out of service.
