InteXX
Mar 08, 2016Luminary
A very LONG scrub
I manually kicked off my first scrub about four hours ago. I'm running 4x4TB WDC Reds @ 5400 RPM on RAID6, resulting in a 7.27TB volume. These are my present stats, calculated in Excel: % ...
- Mar 09, 2016
The scrub will speed up a bit once the filesystem portion of the scrub finishes. But it'll never be "fast" using RAID6 on a RN104. RAID5 can offload some parity calculation work to a specialized engine on the CPU, but no such engine exists for RAID6 on the RN104 CPU, and RAID6 is much more computationally intensive than RAID5. You'd probably have a better experience using RAID10 on RN104.
InteXX
> Which model is this on?
RN104
> Which services and apps are you running?
None
> Which firmware?
6.4.2
Thanks,
Jeff Bowman
Fairbanks, Alaska
mdgm-ntgr
Mar 08, 2016NETGEAR Employee Retired
Is it still suggesting such a long time till completion?
If so, can you send me your logs (see the Sending Logs link in my sig)?
- InteXXMar 09, 2016Luminary
OK, sent.
Yes... but it's now calculating out to be even longer - nearly 10 weeks.
Here are the latest stats:
% Complete : 0.48% Start : 3/8/2016 15:44:03 Current : 3/8/2016 23:19:10 Duration : 1580:15:29 Completion : 5/13/2016 19:34:39
Thanks,
Jeff Bowman
Fairbanks, Alaska
