InteXX
Mar 08, 2016Luminary
A very LONG scrub
I manually kicked off my first scrub about four hours ago. I'm running 4x4TB WDC Reds @ 5400 RPM on RAID6, resulting in a 7.27TB volume. These are my present stats, calculated in Excel: % ...
- Mar 09, 2016
The scrub will speed up a bit once the filesystem portion of the scrub finishes. But it'll never be "fast" using RAID6 on a RN104. RAID5 can offload some parity calculation work to a specialized engine on the CPU, but no such engine exists for RAID6 on the RN104 CPU, and RAID6 is much more computationally intensive than RAID5. You'd probably have a better experience using RAID10 on RN104.
InteXX
Mar 09, 2016Luminary
Hi Skywalker, what about the RN204?
Thanks,
Jeff Bowman
Fairbanks, Alaska
- mdgm-ntgrMar 09, 2016NETGEAR Employee Retired
The RN204 has a dual-core CPU so whether or not it can offload tasks to a special engine it does have two cores to make use of. The RN214 has a quad-core CPU. Performance would be better with either of those.
The RAID itself would be limited to one core, but other things that are running on the NAS could make use of other cores minimising their impact on the scrub.
- SkywalkerMar 09, 2016NETGEAR Expert
Yes, RN204 has RAID6 P+Q offloading.
- InteXXMar 09, 2016Luminary
Excellent, thank you.
Thanks,
Jeff Bowman
Fairbanks, Alaska
So if you want to continue to use RAID-6 the choice would be to consider whether to get the RN204 or the RN214.
The RN214 is a better choice if you wish to e.g. use Plex transcoding, use the anti-virus service and/or use NIC bonding on the NAS with multiple clients accessing the NAS at the same time on a wired gigabit network.
I guess it'll be the RN204 for now. That'll get me by until I eventually get my 516.
But this RN104 has got to go! :-)
Thanks,
Jeff Bowman
Fairbanks, Alaska
