InteXX
Mar 08, 2016Luminary
A very LONG scrub
I manually kicked off my first scrub about four hours ago. I'm running 4x4TB WDC Reds @ 5400 RPM on RAID6, resulting in a 7.27TB volume. These are my present stats, calculated in Excel: % ...
- Mar 09, 2016
The scrub will speed up a bit once the filesystem portion of the scrub finishes. But it'll never be "fast" using RAID6 on a RN104. RAID5 can offload some parity calculation work to a specialized engine on the CPU, but no such engine exists for RAID6 on the RN104 CPU, and RAID6 is much more computationally intensive than RAID5. You'd probably have a better experience using RAID10 on RN104.
InteXX
Mar 09, 2016Luminary
Hi Skywalker, what about the RN204?
Thanks,
Jeff Bowman
Fairbanks, Alaska
mdgm-ntgr
Mar 09, 2016NETGEAR Employee Retired
So if you want to continue to use RAID-6 the choice would be to consider whether to get the RN204 or the RN214.
The RN214 is a better choice if you wish to e.g. use Plex transcoding, use the anti-virus service and/or use NIC bonding on the NAS with multiple clients accessing the NAS at the same time on a wired gigabit network.
