InteXX's avatar
InteXX
Luminary
Mar 09, 2016
A very LONG scrub
I manually kicked off my first scrub about four hours ago. I'm running 4x4TB WDC Reds @ 5400 RPM on RAID6, resulting in a 7.27TB volume.   These are my present stats, calculated in Excel:     % ...
  • Skywalker's avatar
    Skywalker
    Mar 09, 2016
    The scrub will speed up a bit once the filesystem portion of the scrub finishes.  But it'll never be "fast" using RAID6 on a RN104.  RAID5 can offload some parity calculation work to a specialized engine on the CPU, but no such engine exists for RAID6 on the RN104 CPU, and RAID6 is much more computationally intensive than RAID5.  You'd probably have a better experience using RAID10 on RN104.
ProSupport for Business
