DavidTuff
Sep 03, 2017Tutor
Access to ReadNAS RN102 with Android mobile phone
I have a Ready NAS 102 with the current firmware 6.6.0 It is connected to my Netgear Router D6200. Question is, can I run an Android Phone camera to auto record over WiFi to my Readynas? If so, how /...
evan2
Sep 04, 2017NETGEAR Expert
Try to dwonload AnsSMB tool from Google Play, then mount NAS shares to Android local folder,
you my record video to the local folder, it should store data on NAS share (because it mount to the local folder)
DavidTuff
Sep 04, 2017Tutor
Thanks, but what app do I use on the phone to get the video to be sent to the NAS?
- evan2Sep 04, 2017NETGEAR Expert
Could do you please try Open Camera? it can edit saving path in camera settings,
You may download Open Camera in Google Play.
- DavidTuffSep 05, 2017Tutor
Downloaded Open Camera, it seems it will only save to the Android device, no functionallity for it to save on the net..
- evan2Sep 05, 2017NETGEAR Expert
1. Install AndSMB, run it, mount a NAS shanre to Android local foler,
2. Set saving path as the Android Local folder (NAS share mount to the local folder) in Open Camera,
if you record data to the android local folder, actually, data store to NAS Shares because NAS share has mounted to the local folder.
