JakeBloomfield
Dec 09, 2012Aspirant
Accidently added another drive to X-RAID2
Hi All, Quick question - I have 2 x 2TB Western Digital Red drives in my ReadyNAS NV+ V2 in X-RAID. I've added a salvaged generic Western Digital Caviar Green 2TB, forgetting that X-RAID is on, a...
TeknoJnky
Dec 09, 2012Hero
unfortunately, since the readynas added the drive to the volume and expanded/resync'd, if you remove the drive it will cause your volume to be non-redundant (while still staying the expanded size).
there is no way to re-shrink the volume back to 2 disks, you would have to backup all data, factory default with only the 2 disks, restore data/config.
