Bigmaca
Mar 05, 2019Aspirant
'Act' Light Flashing Rapidly - ReadyNAS214 4Bay
Hi there,
I've recently moved house and since moving on occassion my ReadyNas unit will flash rapidly (the act button). I can hear the disks working inside the unit but it is not being accessed or doing anything. If I restart the unit this will resolve it but then a few days maybe hours later it will come back again. I currently use plex on it and when the light flashes quickly it will run a little slower and the accessing of the Admin page is a bit slower. If I turn off the app it will help significantly but doesn't resolve it completely sometimes.
If anyone has any ideas I'd really appreciate it, it's annoying having to go into the admin page all the time to sort this. I've looked through the logs as well and everything appears to be working normally.
Overall, there are various background activities that could account for this. Plex might be reloading metadata, auto-defrag might be kicking in, file search might be updating it's database, etc.
Also, it might have been happening before the move (since the light and the sounds might not have been as noticeable there).
Bigmaca wrote:
As for checking De-Frag where can I find that information?
It's a setting for each share (click on the settings wheel on the share page).
Bigmaca wrote:
Hi Stephen B,
I don't know if I even use all those services. I literally use it for backing up files and using plex to stream my media.
I'd start by disabling several of these services and see if anything changes. If you use Windows, then disable AFP. Also disable ReadyDLNA, NFS, and File Search. In addition disable auto-defrag for each share.
If that seems to resolve the problem, then I'd re-enable auto defrag and file search (one at a time).
Are you using any of the scheduled maintenance functions (on the volume settings wheel)?
What apps and services do you have enabled on the NAS?
Do you have "auto defrag" enabled on the shares?
- BigmacaAspirant
Hi Stephen B,
Thanks for helping.
The Services I have enabled are:
SMB
AFP
NFS
ReadyNAS DLNA
UPnP
HTTP
HTTPS
File Search
Apps:
Plex
I don't know if I even use all those services. I literally use it for backing up files and using plex to stream my media. As for checking De-Frag where can I find that information?
Bigmaca wrote:
Hi Stephen B,
