DirkG
Dec 04, 2016Aspirant
AD Access Problems after upgrading from 6.5.1 to 6.6.0
Hello, after upgrading from firmware 6.5.1 to 6.6.0, some AD users are not able to access the shares. They get the message Access denied, even for folders with access for everyone. I have alr...
- Dec 06, 2016
Hello DirkG,
Sorry, I missed putting "not" in there. It should be read as:
It is just share level, not for sub folder and files permissions, they should be set on the AD server already.
I guess you can try reintegrating, however, I recommend backing up the private/home shares if they have files stored.
JennC
Dec 05, 2016NETGEAR Employee Retired
Hello DirkG,
Have you tried rebooting the NAS?
DirkG
Dec 05, 2016Aspirant
Hello JennC,
I have reebooted the NAS after installing the firmware upgrade to 6.6.0.
Best regards
Dirk
- JennCDec 05, 2016NETGEAR Employee Retired
- DirkGDec 05, 2016Aspirant
Hello JennC,
I sent the logs.
Best regards
Dirk
Hello DirkG,
I checked the logs and found dirk user (I intentionally did not complete the username) is getting an error. I have not seen other users tried to login.
Is the user dirk still listed on the user list? Can you also put a check mark to Allow Anonymous Access box?
