xbmcgotham
Dec 10, 2018Tutor
Added 2x 4TB - Total Storage Volume did not increase
Hi, hope someone can advice.
I am running to the limit of the HD capacity and decided to replace 2 of the current installed disks with 2 higher capacity disks. Followed advise given to me in a ...
- Dec 12, 2018
Thanks again for all the assistance!
It worked.
SOLUTION:
Add first 4TB disk, and let it resync. Then add second 4TB disk, and let it resync. Followed by restarting the unit after the second disk resync is finished. This will enable a new relocation process. After this is finished, the extra TB are added to the available storage amount.
xbmcgotham
Dec 12, 2018Tutor
It worked.
SOLUTION:
