DrJones
Nov 20, 2012Aspirant
Added 3rd drive to Ultra 6...same volume size?
Hi. I have an Ultra 6 with 2x2TB seagate drives. I purchased a third 2tb drive (identical model to the other two) to increase our storage capacity. The NAS sees the drive, worked on it for a whi...
Nov 20, 2012Guru - Experienced User
Perhaps you did not wait long enough (the size is expanded after the disks are restriped). If you are sure that it is finished, try restarting the NAS.
