DrJones
Nov 20, 2012Aspirant
Added 3rd drive to Ultra 6...same volume size?
Hi. I have an Ultra 6 with 2x2TB seagate drives. I purchased a third 2tb drive (identical model to the other two) to increase our storage capacity. The NAS sees the drive, worked on it for a whi...
Nov 20, 2012Guru - Experienced User
Try restarting it again, if that doesn't work submit an on-line support ticket.
You need 4 drives to get dual redundancy, so any setting you applied there is for the next disk, not the three you have installed.
