DrJones
Nov 20, 2012Aspirant
Added 3rd drive to Ultra 6...same volume size?
Hi. I have an Ultra 6 with 2x2TB seagate drives. I purchased a third 2tb drive (identical model to the other two) to increase our storage capacity. The NAS sees the drive, worked on it for a whi...
Nov 20, 2012Guru - Experienced User
Try the restart first, there are other posts here indicating that multiple restarts are sometimes needed. If you pull/reinsert the drive, Frontview will probably treat it as a new drive.
Does the Frontview "volume settings" page say the volume is redundant? Also, does it show same space allocated (e.g. "xxxx GB allocated" on all three drives?
