DrJones
Nov 20, 2012Aspirant
Added 3rd drive to Ultra 6...same volume size?
Hi. I have an Ultra 6 with 2x2TB seagate drives. I purchased a third 2tb drive (identical model to the other two) to increase our storage capacity. The NAS sees the drive, worked on it for a whi...
vandermerwe
Nov 22, 2012Master
Have you tried the suggestions in the links StephenB provided?
If you have then either contact support or if you have a current backup you could try hot removing the new disk and replacing it. There is a risk to data though.
