the_Agent
May 10, 2016Guide
Adding a 3rd Drive to ReadNAS 204 (1660 hours)
Hi there, I got a ReadyNAS 204 and 2 brand new WD Red 5TB. Installing the two drives took the NAS 16 hours. After that I copied 5 TB of Data (95% full) on the NAS. After that I inserted a WD Gree...
- May 18, 2016
Do you still have this problem after updating to 6.5.0?
mdgm-ntgr
May 10, 2016NETGEAR Employee Retired
Which firmware are you running?
There is a known issue with the performance of hot-adding a disk to the array in ReadyNAS OS 6.4.x. There is a fix for this in the next firmware release 6.5.0.
Which services (under System > Settings > Services) and which apps are you running? If you put a high load on a system with e.g. services and apps that can slow down a reshape as well.
the_Agent
May 10, 2016Guide
Hi there,
the NAS is fresh out of the box with no apps installed and Firmware 6.4.2 running.
I only created one folder, copied 5TB of data into it and linked the folder to my PC.
I'm not using the data on the NAS in any way for now.
If it's only a performance problem I just have to wait, right?
Thanx
Wolfgang
- mdgm-ntgrMay 10, 2016NETGEAR Employee Retired
So which services are you running under System > Settings > Services ?
Yes you just need to wait.
