the_Agent
May 10, 2016Guide
Adding a 3rd Drive to ReadNAS 204 (1660 hours)
Hi there, I got a ReadyNAS 204 and 2 brand new WD Red 5TB. Installing the two drives took the NAS 16 hours. After that I copied 5 TB of Data (95% full) on the NAS. After that I inserted a WD Gree...
- May 18, 2016
Do you still have this problem after updating to 6.5.0?
the_Agent
May 10, 2016Guide
Hi there,
the NAS is fresh out of the box with no apps installed and Firmware 6.4.2 running.
I only created one folder, copied 5TB of data into it and linked the folder to my PC.
I'm not using the data on the NAS in any way for now.
If it's only a performance problem I just have to wait, right?
Thanx
Wolfgang
mdgm-ntgr
May 10, 2016NETGEAR Employee Retired
So which services are you running under System > Settings > Services ?
Yes you just need to wait.
- the_AgentMay 10, 2016Guide
SMB, AFP, HTTPS, ReadyDLNA, UPnP and HTTP.
- mdgm-ntgrMay 10, 2016NETGEAR Employee Retired
O.K. so it doesn't sound like you are running anything that should slow the sync to a crawl.
- the_AgentMay 18, 2016Guide
After a week the 3rd drive was perfecly ingetrated.
But writing files to the NAS went from 85MB/Sec (2 Discs) to 18 MB/Sec (3 Discs). Is this normal?
