studioETRE
Jan 09, 2021Aspirant
Adding a volume into ReadyNAS 214: disabling X-raid will cause data loss or is it safe?
Hello: I've a ReadyNAS 214 with two 3TB disks, used as X-raid. Now I want to add two 2 TB disks, but after I installed them, when I clic format, I get an error that says the disk should be equal or...
- Jan 09, 2021
X-RAID is an application built on top of RAID that simplifies expansion. The underlying RAID isn't proprietary, it is built on standard Linux tools. It is limited to a single volume, so you do need to switch to FlexRAID.
It's safe to disable X-RAID. Your existing volume is already RAID-1, and the data won't be lost if you switch to FlexRAID.
Jan 09, 2021Guru - Experienced User
- studioETREJan 10, 2021Aspirant
Thankyou
