Blues11's avatar
Blues11
Luminary
Apr 07, 2019
Adding Seagate IronWold Pro drives
I have 4 bays used with 4TB drives in my 516. I just purchased 2 8TB Seagate IronWolf Pro drives and I can't figure out how to get them into the drive chassis. The caddy or chassis has a slide-out pi...
  • StephenB's avatar
    Apr 08, 2019
    You need to remove the plastic mounting bracket (with the nibs), and use the screws that came with the NAS to attach the disks to the bottom of the tray.  One pair of holes will align with the mount points on the bottom of the disk.  That will still attach the drive firmly to the tray.
    The instructions for removing the bracket are in the hardware manual (page 171 and following): http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf  Though the section overall is on adding a 2.5" disk, the procedure for removing the plastic mounting bracket still applies.  There's a similar guide here: https://kb.netgear.com/22894/ReadyNAS-OS-6-Adding-a-disk-to-desktop-models
    Blues11 wrote:
    Why is there a nib where there is no hole?
    When the NAS was designed (and likely when you purchased it) all disks had side center mount holes.  As disk capacity has increased, manufacturers have needed to maximize room for the platters inside the disks.  So center mount holes have been dropped on many disk models (and also center mount holes on the bottom).  This new arrangement of "alternative mount points" isn't full accomodated by your older NAS.   Currently shipping ReadyNAS have modified trays - with more bottom screw holes, so they will accomodate these larger disks.
ProSupport for Business
