Acro
Nov 23, 2015Aspirant
Adobe Lightroom & Photoshop not working with ReadyNAS storage
I recently upgraded my MAC OS to El Capitan and shortly afterwards was prompted to upgrade my Lightroom and Photoshop CC apps. Since them I am having major problems with Lightroom and Photoshop and ...
Nov 23, 2015Guru - Experienced User
What NAS and what firmware is it running? Are you sharing with SMB, AFP, or NFS?
- AcroNov 23, 2015Aspirant
Its a ReadyNAS Duo v2 running RAIDiator 5.3.11 and I'm connecting to it using AFP.
Just had some feedback from somebody on the Photoshop community forum and based on that I switched off my AV, which is Trend Internet Security. That seems to have fixed it. Must be some conflicts with the way real-time scanning works with NAS drives.
- Sean1972Dec 07, 2015Aspirant
Im having problems also. I'm new to NAS devices but since buying the ReadyNAS 102 I'm having lots of errors reading images via Adobe Lightroom (needless to say before adding the NAS everything was fine)
Im using the NAS plugged directly into the Netgear Router, I've also tried it plugged directly into the laptop via the ethernet cable.
Im using a MacBook Pro, and Adobe Lightroom CC.
I get various symptoms, such as 'Unexpected File End' and also images only partially loading
I have screenshot examples but cant seem to attach them this thread.
Netgear support don't appear to know what to do, however they've hinted that the MTU settings may need to be altered but were not defininate about it.
Any help much appreciated.
Sean
