jonathan_ibell
Oct 13, 2012Aspirant
Advice re slow internal transfer speeds on Duo V2
Hi I recently set up my ReadyNAS Duo v2, and ever since I have been getting terrible transfer speeds - not only between my laptop and the NAS, but also even within the NAS itself. Eg, copying a file...
jonathan_ibell
Thanks for your reply and suggestions - good to know I should be able to do what I'm after.
Can anyone with a v2 be able to advise me how to "use the admin credentials and open the volume itself"? Apologies for my ignorance here but I'm not sure exactly how this acheived.
Cheers
Jonathan
StephenB wrote: The way to move files on the NAS (within the same volume) is to use the admin credentials and open the volume itself (C). Then you can move files without copying them to the PC and back again (using only one explorer window).
You should also be able to copy folders within the NAS by using Frontview backup.
Cheers
Jonathan
