jonathan_ibell
Oct 13, 2012Aspirant
Advice re slow internal transfer speeds on Duo V2
Hi I recently set up my ReadyNAS Duo v2, and ever since I have been getting terrible transfer speeds - not only between my laptop and the NAS, but also even within the NAS itself. Eg, copying a file...
Oct 13, 2012Guru - Experienced User
You do need the \C. The other option is to set the NAS credentials in the Windows credential manager (in the control panel) to use admin and the NAS password. Then if you accessed \\NAS you would see the C volume as a folder.
What firmware version are you running? The ability to access the C volume was not in the first firmware release.
You should get fast speeds when moving within the same share. The copy / copy back happens when you try to move between shares (or perhaps between explorer windows). When you access the C volume you see all the shares as folders within the volume, allowing you to move files between shares w/o the network copies.
