thom1
Sep 18, 2009Aspirant
afp connection rejected: (bad user/pass) afp log: "too many"
I just solved my own problem, but not without a lot of frustration and head-banging. Here was the post I was writing (eg in the *present* tense) to describe the situation: On my macbook pro, ru...
Tobermory
Jun 29, 2010Aspirant
sphardy wrote:
Tobermory wrote: Hi, I cannot connect to AFP all of a sudden either. These are the contents of my /etc/default/netatalk: <Directory "/home/ftp/Toshiba">
HideFiles none
<Limit WRITE READ>
Order deny,allow
Allow from all
</Limit>
UserOwner root
GroupOwner root
</Directory>
Is this normal?
Tahnks.
No - absolutely not. This is configuration data for the FTP server. Try the fix mentioned above
Thankyou, that has resolved the problem and AFP is now working. I was unable to paste the # symbol into the file using vi and I got a comment at the bottom of the screen saying '# not implemented'. I understand this is just a comment line so deleted it.
All of these problems have appeared since I tried to add a new disk which turned out to have SMART issues. I have also recently opened up FTP access from the internet. Could any of these things have caused the errors and should I be aware of anything else - just in case?
Thanks for the support. Quicker than Netgear's response!
