thom1
Sep 18, 2009Aspirant
afp connection rejected: (bad user/pass) afp log: "too many"
I just solved my own problem, but not without a lot of frustration and head-banging. Here was the post I was writing (eg in the *present* tense) to describe the situation: On my macbook pro, ru...
sphardy1
Jun 29, 2010Apprentice
I really don't know what could cause this - the file you refer to is a system setup file for AFP access, is not typically user accessible, and should never be, or need to be, changed. So why it should be truncated/deleted/modified is a mystery to me. Even adding a hard disk should not cause this.
Needs the netgear dev's to investigate
