waldog
May 29, 2015Aspirant
AFP stopped connecting
Hi I'm using a ReadyNAS NV+, which I use as a time machine backup on a Mac running OSX 10.9.5 (Mavericks). Until recently this was working fine, then for no reason I've been able to discern, the A...
vandermerwe
May 29, 2015Master
Do you have a backup of the the data that is on the readynas? I understand you're using it to backup your Mac, but is there any other data on it?
Are there any addons installed?
Is AFP still enabled under services? - not under the share settings but on the file protocols tab?
You haven't changed any of the permissions for the share? What are the settings?
How full is the data volume?
Do you have ssh enabled?
If you have ssh enabled you should check the OS partition fullness using these commands:
Unlikely to be that though, more likely a network access permissions issue.
df -h
df -i
