waldog
May 29, 2015Aspirant
AFP stopped connecting
Hi I'm using a ReadyNAS NV+, which I use as a time machine backup on a Mac running OSX 10.9.5 (Mavericks). Until recently this was working fine, then for no reason I've been able to discern, the A...
waldog
Jun 20, 2015Aspirant
Sorry for the long delay in replying. I thought I had checked "notify me" but obviously not.
Yes, there is other data on the volume (a different partition to that which I use for Time Machine backup). Neither is accessible through the AFP. I can access the general volume through CIFS just fine.
No, additional addons are all disabled.
Yes, under "Standard File Protocols" AFP is enabled, and set to advertise over both Bonjour and AppleTalk. I tried disabling and re-enabling these settings – no dice.
No share permission changes were made before the AFP stopped working. CIFS, NFS and AFP all show up as enabled on the share.
56% of an X-RAID configured setup.
I don't seem to have ssh enabled – my attempts to ssh in as the root user were all refused. I looked at this thread (http://www.readynas.com/forum/viewtopic.php?f=36&t=30331) and this page (https://www.readynas.com/?page_id=617) but I'm not sure how to install the EnableRootSSH binary.
Any other suggestions?
vandermerwe wrote: Do you have a backup of the the data that is on the readynas? I understand you're using it to backup your Mac, but is there any other data on it?
vandermerwe wrote: Are there any addons installed?
vandermerwe wrote: Is AFP still enabled under services? - not under the share settings but on the file protocols tab?
vandermerwe wrote: You haven't changed any of the permissions for the share? What are the settings?
vandermerwe wrote: How full is the data volume?
vandermerwe wrote: Do you have ssh enabled?
If you have ssh enabled you should check the OS partition fullness using these commands:df -h
df -i
waldog
Aug 04, 2015Aspirant
Bump. Does anyone have ideas on how to fix this? I'm starting to worry that I may have lost my backed up files...
