495brian
Nov 14, 2016Aspirant
After Factory reset, quickest way to X-Raid2 with Dual redundancy 6x 2TB drives (RNDP6000)
I have 3 of the pro ready NAS drives (6 bays), one business and to readynas pro RNDP6000. One is set up as the "in use" drive and the other two are for back up. The "in use" drive was set up as XRA...
mdgm-ntgr
Nov 14, 2016NETGEAR Employee Retired
The quickest way on RAIDiator-x86 would be to do a factory reset, click setup in RAIDar during the 10 minute countdown and choose X-RAID2 and check the dual-redundancy option.
On OS6 the quickest way would be to disable X-RAID, delete the default volume and create a new one using RAID-6 and then re-enable X-RAID. It's preferable to call the new volume "data" (no quotes).
495brian
Nov 16, 2016Aspirant
Hi All- Just an update to the process for other out there. The reboot with 5 drives was quick, less than 10 minutes to set up and establish a new volumne. The 5th drive to re-sync took about 4 hours, but I let it run overnight. Following this completion a login through RAIDar allowed me to select what the option would be for the next drive to expand the volume or add dual redundacy. I selected Dual and popped in the 6th 2TB drive. The restripping is now occurring and will take 120 hours!
As I've read this process is increased due to the drive size (not data because the volume is still empty), but I was shocked it will take so long.
Have others had this same experience for time for restriping?
- StephenBNov 16, 2016Guru - Experienced User
In my experience the estimated times are not very accurate. The process does happen in the background, so actual time depends on what else the NAS is doing.
- 495brianNov 17, 2016Aspirant
Thanks SetphenB,
I was hoping that was the case, but it really looks like it will take another 80 hours...about 1% / hour. I'm hoping the process doesn't run into any troubles so I can begin to back up the other NAS and be done sometime before thanksgiving!
Best,
Brian
