Masterkennie
Jul 16, 2017Aspirant
After Firmwareupdate to 6.7.5 the admin page is not reachable
Hello, i need some help with using my readyNAS RN102. Yesterday I got the message, that a new firmware update 6.7.5 is available. After automatic installation of this update by using the admin page ...
howtont
Jul 28, 2017Aspirant
I have the same problem with my ReadyNAS 214. After firmware update to 6.7.5 the admin page is offline and I've tried all the recommended methods to get to it. Yes, I've tried the FWBroker and it finds the NAS just fine. I've run the update with it, but it's already at the most current version.
I can get to the NAS through Ready Cloud as well, just can't access the Admin page. I've double checked to make sure I'm on the same network... using a Netgear Nighthawk R8500.
The apps on the NAS are running fine. I've also Netgear RAIDar. Everything looks healthy on the NAS. Ran Diagnostics, no issues. But when I try going to the admin page, it's a no-go.
Any help would be appreciated.
Jul 29, 2017Guru - Experienced User
You likely will have success if you install 6.8.0-rc1 via fwbroker.
- vikramdabasJul 29, 2017Aspirant
I am also not able to login to admin panel after 6.7.5 update, plz help. My fwbroker shows error 6001010007.
- Marty_MJul 31, 2017NETGEAR Employee Retired
Can the raidar still detect the NAS on the network. Can you download and provide us a copy of the logs you use web sharing site like wikisend and PM me the download link. Also try accessing the admin page from different computer and browser.
Marty_M
NETGEAR Community Team- vikramdabasJul 31, 2017AspirantYes i can access data using raidar. Even customer support told me to reinstall os from reset button. Admin not working. I checked logs. Its apache server that is creating problem. That's why i am not able to access admin panel. But I'm able to access files from folder address bar. Plz tell me how can i resolve the issue. http log file contain these lines.....
Jul 30 10:14:53 ReadyNAS apache2[2484]: apache2: Syntax error on line 244 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/mods-enabled/php5.load: Cannot load /usr/lib/apache2/modules/libphp5.so into server: /usr/lib/apache2/modules/libphp5.so: cannot open shared object file: No such file or directory
