Masterkennie
Jul 17, 2017Aspirant
After Firmwareupdate to 6.7.5 the admin page is not reachable
Hello, i need some help with using my readyNAS RN102. Yesterday I got the message, that a new firmware update 6.7.5 is available. After automatic installation of this update by using the admin page ...
howtont
Jul 29, 2017Aspirant
I have the same problem with my ReadyNAS 214. After firmware update to 6.7.5 the admin page is offline and I've tried all the recommended methods to get to it. Yes, I've tried the FWBroker and it finds the NAS just fine. I've run the update with it, but it's already at the most current version.
I can get to the NAS through Ready Cloud as well, just can't access the Admin page. I've double checked to make sure I'm on the same network... using a Netgear Nighthawk R8500.
The apps on the NAS are running fine. I've also Netgear RAIDar. Everything looks healthy on the NAS. Ran Diagnostics, no issues. But when I try going to the admin page, it's a no-go.
Any help would be appreciated.
Jul 31, 2017Guru - Experienced User
You're running the current released firmware. Some users in your situation found that manually installing 6.8.0 beta via fwbroker fixed this issue. It's currently at RC-1, and I've found it to be stable.
- vikramdabasJul 31, 2017AspirantHey, my fwbroker is giving me error 6001010007. How can i manuaaly update the readynas 102 to 6.8.0 rc. Plz guide me. I'll do it. I need admin panel access asap. It's very imp for me Right now..
- StephenBJul 31, 2017Guru - Experienced User
Did you download the RN102 (arm) beta, and then use "choose file" to select it followed by "update"?
At what point did you see the 6001010007 error?
- vikramdabasJul 31, 2017AspirantWhen i tried to access fwbroker.. Like 192.168.0.50/fwbroker
It give me error.
- howtontJul 31, 2017Aspirant
That's what I tried after trying everything else. Once the 6.8.0 beta was installed, the admin page came back and everything is working great. They need to put that version out as a regular upgrade!
