hmuessig
Dec 17, 2016Luminary
Alerts Fail to Send (repeatable error - bug)
Email alerts on my RN 314 have been working just fine since I got it three years ago. The email is a GMAIL account with two-factor authentication and I just use a Google generated applicaiton specifi...
- May 09, 2017
I am delighted to report that this issue is fixed with OS 6.7.1!
After the update I tried to send a test message with the old settings (email address and password) and it failed. Reentering the password resulted in a successful test message and messages the past two days about backups completing, UPS issues (storms here), and a scheduled event (scrob) that started and completed.
Tx!
buriedpast
Apr 26, 2017Guide
I'm having this same exact error on my legacy Ultra 6 Plus running OS 6.6.1. Using either Gmail or Hotmail, my test messages initially go through. However, after logging out of the admin panel and logging back in, any attempt to send a test messages fails with the same error message:
msmtp: authentication method LOGIN needs a password msmtp:
could not sent mail (account default from /etc/msmtprc)
Re-enter the password and the test message sends successfully.
Maybe OS 6.7.1 will fix the problem when it comes out. In the interim, any suggestions? I'm striking out with my search of the internet.
And yes, I have "Access for less secure app" enabled.
Thanks in advance.
Apr 26, 2017Guru - Experienced User
Is this only test messages? There have been similar bugs on them before.
Try something that generates a real message, and see if that works. A balance will do it. You can also create a back job configured to fail - that will also send an email.
- buriedpastApr 26, 2017Guide
It's pretty confusing, but here's the information I have to offer at this time:
I tested using both Firefox and IE 11 with the same results. (Tried IE since I recall seeing a message regarding current browser compatibility, figured what the heck) Type in the password and click "Send test message and apply" and the message goes through successfully. Don't touch anything and send the test message again and it goes through successfully. Try the third time and the test message fails. This symptom is repeatable with either browser, tried it two times with each.
Thought three times may be the problem with any other type of message, so I used the test message button to apply the settings (you can't save settings without sending the test message) and performed a balance. Message went through successfully. Tried three more balances and notifications of starting and completion went through each time.
Played around with the test message until if failed the third try and then tried balancing ... the notifications didn't complete. So, when it says the email configurations won't work, it means it.
No idea why test messages are messing up, but I'm now set with a single successful test message being sent and I'll not touch it anymore. I'll now wait to see how my routine balancing and scrubbing on the first of May turn out. Hopefully, email notifications will be sent successfully.
There's a bug somewhere, I figure it will be fixed sometime down the road.
Thanks!
- hmuessigApr 26, 2017Luminary
buriedpast:
Glad you've been able to reproduce the error. I have not worked on it in a while -- been buried in other stuff.
Is there a specific action you can identify that "broke" the alerts? Mine appeared to "break" when I changed email addresses for the notices.
I'd been using the same email address for about 3 1/2 years when changes with Gmail (apparently) caused the alerts to no longer function.
Putting in a new email address, that is replacing the original one, started the problems for me.
My suspicion (old programming hat) is that there is a bug in the way either the new email address or password is stored, or more properly, replaces the ones entered when the alerts are first set up.
I am going to guess that if Netgear sets up a new NAS and sets up (for the first itme on that NAS) email alerts that the alerts will work. If they then change the email address for the alerts the alerts will fail.
This is an annoying enougnh bug that I wish Netgear would put some effort into fixing it. Particularly since you can reproduce the problem
Thanks!
- StephenBApr 27, 2017Guru - Experienced User
Of course when you do change to a different gmail account, you do have to make sure that 2-factor authentication is disabled, and "allow less secure" apps is enabled.
If I remember correctly, some years there was a bug specific to sending a test message - the saved password somehow got cleared. I believe that was fixed but am not sure.
Email alerts using gmail work for me, I receive a backup confirmations, etc all the time.
