mthomtech
Apr 16, 2016Tutor
All data usage showing up as snapshots
I'll preface this with the fact that I have no idea when this phenomenon showed up because I had not looked at my admin page in quite awhile. I use my NAS 104 primarily for DVD storage for my HTP...
- Apr 17, 2016
A one-off snapshot upgrade didn't take place on your system.
I have sent you a PM.
mdgm-ntgr
Apr 16, 2016NETGEAR Employee Retired
If the balance doesn't resolve it send me your logs (see the Sending Logs link in my sig).
mthomtech
Apr 17, 2016Tutor
Balance freed up a little space, but the data / snapshot mix didn't change. Still show 26.8GB data and 5.05 TB of snapshots. Shot you over the logs. Thanks!
- mdgm-ntgrApr 17, 2016NETGEAR Employee Retired
I have sent you a PM. - mdgm-ntgrApr 18, 2016NETGEAR Employee Retired
Looks like your system has dropped off Secure Diagnostic Mode. It was in the middle of upgrading your snapshots.
If you can connect to the system please disable/re-enable Secure Diagnostic.
If you can't reboot the NAS and re-enable Secure Diagnostic Mode and let me know when done.- mthomtechApr 18, 2016Tutor
Yes - looks like my broadband went down for a minute ... I lost all connectivity. I'm back up and dasabled and re-enabled. Same code.
Thanks!
The quotas are being recalculated. This may take quite some time.
You should gradually see that the amount shown in the UI as consumed by current data increases till it reaches the correct value.
