TigerRob
Nov 16, 2016Tutor
All Shares appear to be missing [ReadyNAS Ultra 2; Radiator 4.2.28]
Some weeks ago I (possibly stupidly) ignored a reported filesystem consistency check failure. Have had the check pass successfully since. Today I discovered that I can no longer connect to any o...
bedlam1
Nov 16, 2016Prodigy
This post might help you out as a start https://community.netgear.com/t5/Using-your-ReadyNAS/How-do-i-clean-md0/td-p/1138772
One other option is to perform a Factory Reset (this wipes ALL data, so get a full backup), if you go down that route you may want to consider upgrading to the latest OS 6 system
see here http://netgear.nas-central.org/wiki/OS6_on_Legacy_x86
- StephenBNov 16, 2016Guru - Experienced User
Do you have crashplan installed?
- TigerRobNov 17, 2016Tutor
StephenB - yes I am running Crashplan. From other threads it appears there might be some Crashplan directories that grow (and should be moved onto a data partition). Pointers for cleaning up the crashplan installation and moving the appropriate directory would be much appreciated.
