TigerRob
Nov 16, 2016Tutor
All Shares appear to be missing [ReadyNAS Ultra 2; Radiator 4.2.28]
Some weeks ago I (possibly stupidly) ignored a reported filesystem consistency check failure. Have had the check pass successfully since. Today I discovered that I can no longer connect to any o...
Nov 16, 2016Guru - Experienced User
Do you have crashplan installed?
TigerRob
Nov 17, 2016Tutor
StephenB - yes I am running Crashplan. From other threads it appears there might be some Crashplan directories that grow (and should be moved onto a data partition). Pointers for cleaning up the crashplan installation and moving the appropriate directory would be much appreciated.
- TigerRobNov 17, 2016Tutor
StephenB Found this thread https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/m-p/987406#M10801
I suspect that gives me enough pointers - will investigate later.
- TigerRobNov 18, 2016Tutor
Thank you all for your help (esp. StephenB for the mention of crashplan)
3.5GB in /usr/local/crashplan/iupgrade ...
Stopped crashplan, moved that directory off to the data partition and softlinked to it, rebooted, and I appear to be back in business.
- StephenBNov 18, 2016Guru - Experienced User
You will need to get the upgrade to 4.8 to work, otherwise the problem will come back. I had to create a .wgetrc file to disable the certificate check to get the upgrade to complete.
