ChaseB
May 10, 2015Aspirant
Allowing only whitelisted IP addresses
Hi, was wondering if it were possible to restrict remote access by IP? For example, I travel a lot but use a VPN for a static IP, is it possible to whitelist this IP as the only one able to access th...
EskenderNG
May 10, 2015NETGEAR Employee Retired
Hi,
Which ReadyNAS are you using by the way? Is the VPN tunnel ending at your home or are you using a rented/free service with an unencrypted segment between the VPN server and your home? In case of the latter and if using ReadyCLOUD/ReadyNAS Remote it might be difficult to setup a whitelist as several IPs of Netgear’s servers would probably need to be whitelisted rather than the VPN server IP.
In any case, I don’t think the ReadyNAS Firmware offers an option for whitelisting IPs. Maybe you could look at your router rather than the ReadyNAS for IP-based access restriction.
However, I do like your request for this security feature although demand might be limited at least on the home user side.
Bye,
Eskender
Bye,
Eskender
