ChaseB
May 10, 2015Aspirant
Allowing only whitelisted IP addresses
Hi, was wondering if it were possible to restrict remote access by IP? For example, I travel a lot but use a VPN for a static IP, is it possible to whitelist this IP as the only one able to access th...
May 10, 2015Guru - Experienced User
I think the main issue here is that most people are getting dynamic IP addresses while on the road. And in the case of a VPN tunnel that is not terminating in the home there would need to be some clarify on which IP address is being whitelisted. So I agree that use of this particular feature would be limited.
Though there are some applications - particularly if you are wanting to access the NAS between two business locations.
