ChaseB
May 10, 2015Aspirant
Allowing only whitelisted IP addresses
Hi, was wondering if it were possible to restrict remote access by IP? For example, I travel a lot but use a VPN for a static IP, is it possible to whitelist this IP as the only one able to access th...
mdgm-ntgr
May 10, 2015NETGEAR Employee Retired
Between two business locations I'd recommend a vpn endpoint router at each end.
