nitro001
Jul 06, 2016Aspirant
Amazon Cloud Drive 1-Way Sync and Encryption
Hello, I have been a long time NV+ user (9 years), and an NV user before that. I wrote a thread a little while ago contemplating updating from the NV+ to a newer model, looking for something that d...
BrianL2
Jul 07, 2016NETGEAR Employee Retired
Hi nitro001,
Amazon Cloud Drive or ACD, does bidirectional (two-way) sync. You can select share/s from your ReadyNAS system that you want to sync with your Amazon Cloud Drive folders. Lastly, the backup or sync is HTTPS (SSL) encrypted.
Kind regards,
BrianL
NETGEAR Community Team
- StephenBJul 08, 2016Guru - Experienced User
But the files themselves are not, correct?
- BrianL2Jul 12, 2016NETGEAR Employee Retired
Hi StephenB,
Though we transmit data securely through an encrypted tunnel to ACD, we don't encrypt files.
Kind regards,
BrianL
NETGEAR Community Team- pingjockeySep 10, 2016Tutor
Brian and Readynas team:
File encryption would be an awesome feature to have so that I can securely (well as securet can in a cloud environment) store offsite copies of my files.
