Mr_HoneyDo's avatar
Mr_HoneyDo
Another 6.7.3 firmware failure!
Upgraded from what I believe was firmware 6.7.1 to 6.7.3 on my RN516 and now the device won't boot.  Shortly after restarting its froze on:   lcd_panic_handle r+7d   I'm assuming the solution for...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    May 26, 2017
    If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
    If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
ProSupport for Business
