wDahl823
Sep 29, 2018Tutor
EX7000 Firmware Update Failure
Received email from Netgear about a new FIRMWARE update. Logged onto Netgear website. Clicked on message "New update is available. Click here to start." Clicked on "here" and received this message:
A New Firmware Version is Found. Do You Want to Update to the New Version Now?
- Release Notes
 - 1. [Bug Fix] Fixed several security bugs.
Responded yes to UPDATE and recevied this message: "GUI Language File is Invalild"
Also tried to manually upload and install but, got same error. Anyone else ran into this problem or has a solution?
Check out my reply to this thread. I was having the same issue and downloaded the update manually.
- wDahl823Tutor
Worked Perfect!!! Thanks Very Much! I really appreciate you taking time to provide me with a solution.
- Glad to help =]
 - JoeyircAspirant
Okay I installed the new firmware update and it failed. I since went back to the previous firmware according to the community and got back online. Has a fix been posted yet? I am currently running v1.0.0.66_1.0.126
- Cris_MGuide
I haven't been notified of a fix as of yet. Still waiting on Netgear to consider my active ticket resolved.
Maine supposedly took the update but keeps on causing intermitant reset. Anyone else having this issue?
- Cris_MGuide
After about 12 hours of good performance, I started having issues again. I looked at my Modem Router's logs and consistently continue to see a "WLAN access rejected: incorrect security" error. This error is attached to the extender's MAC addresses and shows up once every 5 minutes or so. Once I revert to the previous firmware, I stop seeing this error on my modem Router's log. This may be the reason for a continuous inconsistent internet connection. PLEASE FIX THIS NETGEAR!!!
- bllfr0gGuide
I get the intermittent reset, had to roll back to get stable performance.
Hope Netgear even reads these, and will fix soon.
