Mr_HoneyDo
May 25, 2017Aspirant
Another 6.7.3 firmware failure!
Upgraded from what I believe was firmware 6.7.1 to 6.7.3 on my RN516 and now the device won't boot. Shortly after restarting its froze on: lcd_panic_handle r+7d I'm assuming the solution for...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
zero11
May 25, 2017Tutor
Can you send me one too? I have posted in two other places about getting "lcd_panic_handle r+7d" or "lcd_panic_handler+7d" displayed on one of my 314's.
mdgm-ntgr
May 25, 2017NETGEAR Employee Retired
Sure. I've sent you a PM too.
- Langzik_NASMay 26, 2017Guide
Is this problem being handled strictly via PM? I'm not seeing any DIY solutions being posted.
I have the same issue. I waited about a day [after the most recent OS update] for the problem to remedy itself, then tried rebooting manually (through a 3rd party, because I'm currently in Europe and my NAS is in North America).
Sequence of events (according to the front LCD screen) on a per-reboot basis:
Booting.
Starting Network.
lcd_panic_handler+7D
Any help would be appreciated; thanks in advance. :)
- Thomas- mdgm-ntgrMay 26, 2017NETGEAR Employee Retired
Langzik_NAS I've sent you a PM as well, but if you can please try USB Boot Recovery first.
