bstinson
Apr 26, 2018Star
Antivirus Protection
Does the built in antivirus protection scan everything including FTP traffic?
Retired_Member
Apr 27, 2018To my understanding it is scanning files being put on the system, that should include all protocals/channels bringing the content to the nas.
Somebody with deeper insight might want to comment. Thanks.
bstinson
Apr 27, 2018Star
Thanks for the reply. If anyone else has any insight regarding this, responses are appreciated.
- StephenBApr 27, 2018Guru - Experienced User
It's looking at the file system - it doesn't know (or care) what application wrote the files to the file system.
- bstinsonApr 30, 2018Star
Very good. Thanks, that's what I wanted to hear.
- bengsigJun 17, 2018Aspirant
The software doc to ReadyNAS OS 6.9.3 says it only scans when writing files over SMB (i.e when writing from a Windows share. Here's a qoute:
"When enabled, the antivirus software scans new files as they are written over the SMB (CIFS) protocol. It does not scan existing files or files transferred over other protocols."
