Grunchy
Aug 28, 2021Aspirant
Anybody know how big a volume I can create with Radiator 4.2.31?
I've got these Western Digital 6TB gold drives (please see attached file). Here's the thing. If I let the ReadyNas 2100 create an X-Raid2 volume it uses up all of the space, and then it says the ...
- Aug 28, 2021
Thanks everybody for your advice.
The final number: 16,273,912 MB is what you would put in. That's including "10 GB" for snapshots, although I think the software is in error, I think that really means "10 %" for snapshots.
(If you put 16,273,913 MB that is the smallest size that is too big to be created into a successful volume.)
For ReadyNas 2100 v1 running Raidiator 4.2.31.
Aug 29, 2021Guru - Experienced User
Sandshark wrote:
It would still be interresting to see the results of those commands to see what's causing that limit.
One reason for the inability to expand over 16 TiB is the inode size. The system uses 32 bit inodes if the initial volume is < 16 TiB, and that can't be safely changed later (at least in the ext software in the 4.2.x ReadyNAS). You need 64 bit inodes if the volume is > 16 TiB.
But in this case (4x6TB drives), the system should have chosen 64 bit inodes.
Sandshark
Aug 30, 2021Sensei
Interesting.
--- Volume group --- VG Name c System ID Format lvm2 Metadata Areas 1 Metadata Sequence No 2 VG Access read/write VG Status resizable MAX LV 0 Cur LV 1 Open LV 1 Max PV 0 Cur PV 1 Act PV 1 VG Size 16.01 TB PE Size 64.00 MB Total PE 262303 Alloc PE / Size 262143 / 16.00 TB Free PE / Size 160 / 10.00 GB VG UUID tK4AtE-uzFv-xv6z-IJj3-xeM9-9ZQt-3lpLca
I haven't quite figured out how they got that number, but it's good info for anyone with an NVX, 1500, or 2100V1.
- StephenBAug 30, 2021Guru - Experienced User
Sandshark wrote:
For some reason, Grunchy could not respond in the forum, but he provided the following in an IM
The automatic spam filter kicked in. I released the more recent post.
Sandshark wrote:VG Size 16.01 TB Alloc PE / Size 262143 / 16.00 TB
So a 16 TiB ceiling on the 32 bit 4.2.x NAS.
Grunchy: One option is to switch to flexraid with only three of your disks in place, and set that up as RAID-5 (volume c). Then hot-insert the last disk and set it up as RAID-0 (volume d). You'd get 12 TB in the c volume, and 6 TB in the d volume. You wouldn't have RAID redundancy on the d volume.
