dannieboiz
Oct 02, 2014Tutor
Anyone got 6.2 on their legacy RN yet?
Didn't see any post on this topic, do you install 6.1 from the other thread then just upgrade from frontview?
mdgm-ntgr
Oct 02, 2014NETGEAR Employee Retired
Yes, they do. See http://www.readynas.com/forum/viewtopic.php?f=161&t=77780
You could install the 6.1.x image from the other thread then after the necessary factory default (either triggered as a result of installing the Prep add-on before the firmware update or manually via the boot menu) use the Dashboard to upgrade to 6.2.0.
If you prefer you could use this one to go direct to 6.2.0 beta.
