dannieboiz
Oct 02, 2014Tutor
Anyone got 6.2 on their legacy RN yet?
Didn't see any post on this topic, do you install 6.1 from the other thread then just upgrade from frontview?
mdgm-ntgr
Oct 02, 2014NETGEAR Employee Retired
Any of our current models can be joined to a domain. Still it is important especially for large purchases to make sure you are buying the right product for what you need.
Models such as Duo v2, 102 and similar models from other vendors come with ARM CPUs and low amounts of RAM. This may be fine, but you do need to evaluate whether it will handle the load you will put on it.
The 312 with its Intel CPU and 2GB RAM can handle a higher load.
