dannieboiz
Oct 02, 2014Tutor
Anyone got 6.2 on their legacy RN yet?
Didn't see any post on this topic, do you install 6.1 from the other thread then just upgrade from frontview?
mdgm-ntgr
Dec 16, 2014NETGEAR Employee Retired
Now that you are running OS6 you can use the standard x86_64 builds. When a production update is made available you will even be prompted to update when opening the Dashboard.
