steveoelliott
Nov 23, 2016Luminary
Apache and SSL certificate problem
Hi all, I see the following within my log and this is clearly due to me changing the hostname of the NAS. Is there a way to regenerate these certificates safely or do folks just generally ignore ...
Nov 23, 2016Guru - Experienced User
steveoelliott wrote:
I see the following within my log and this is clearly due to me changing the hostname of the NAS. Is there a way to regenerate these certificates safely or do folks just generally ignore this.
Since the certs are self-signed, you will get warnings in the browser unless you go to the trouble to add them to the root store. So personally I just click through the browser warnings.
If you go into system->settings->https, you can change the SSL key to match your hostname and then click apply.
- steveoelliottNov 23, 2016Luminary
I thought as much... Will change the hostname for cleanless though.
Thanks...
