zeke561
Jan 05, 2018Guide
Apparently conflicting backups causing crash
Hi I have a ReadyNAS running ReadyOS 6.9.1 that is dedicated as a backup server to back up a couple of other units via Rsync. These backups are done every hour, 24/7. This has been working fine for ...
Jan 05, 2018Guru - Experienced User
Is your local backup set up with a local source and a remote destination? Or is it the other way around?
If you have a local source, the NAS should be making a snapshot of the source, and then backing up the snapshot. The snapshot is deleted when the backup completes. That should avoid your issue.
zeke561
Jan 05, 2018Guide
Hi
The local backup is set to a local source and local distination (i.e. an external usb disk).
- StephenBJan 05, 2018Guru - Experienced User
zeke561 wrote:
Hi
So the local backup isn't using rsync?
The NAS should be backing up a snapshot no matter what protocol you are using - hopefully someone from Netgear can confirm.
- zeke561Jan 05, 2018Guide
Hmm, I'm not sure that the backup of multiple shares to disk at the same time is working. I tried to start one after the other from the web interface and get an indication that three jobs are in progress. I thought they would be queued. I also am getting a msg on the front panel that says "mb_cache_entry_insert+54". And the backups are taking an inordinate amount of time.
BTW I should mention that this is on a legacy Pro 4 machine. So maybe there is not perfect support for the hardware? At any rate, I think I am on my way to another crash. I just rebooted.
Possibly you are running out of memory? The Pro shipped with 1 GB, the current OS-6 NAS ship with at least 2 GB.
