zeke561
Jan 05, 2018Guide
Apparently conflicting backups causing crash
Hi I have a ReadyNAS running ReadyOS 6.9.1 that is dedicated as a backup server to back up a couple of other units via Rsync. These backups are done every hour, 24/7. This has been working fine for ...
zeke561
Jan 05, 2018Guide
Hi
The local backup is set to a local source and local distination (i.e. an external usb disk).
Jan 05, 2018Guru - Experienced User
zeke561 wrote:
Hi
So the local backup isn't using rsync?
The NAS should be backing up a snapshot no matter what protocol you are using - hopefully someone from Netgear can confirm.
