spiderman1
Jan 20, 2014Guide
APT-GET on Readynas Pro
Hi guys, I would like to now how to get apt-get to work on my Pro as I would like to install dmidecode. I have done the following via ssh: READYNASPRO:~# apt-get update Hit http://www.read...
mdgm-ntgr
Jan 20, 2014NETGEAR Employee Retired
1. It is dmidecode not demidecode
2. You need to edit /etc/apt/sources.list to include more than just ReadyNAS.com sources
3. If you extracted the contents of the BIOS upgrade add-on you should find a copy of dmidecode in there, I think.
